Solved... thanks
i took my board for a ride, it was all good, but when i return home, one of my motor stop,
i try my good motor in both vesc, all good. pretty sure i didnt blown my vesc…
when i try my other motor (the one that stop) it has this faults on same vesc, and detection error, bad detection
my setup 200kv 10s
also tried to check motor manually (phase wire together) the motor is spinning, and when i connect the phase wire together is has resistance… i have read some related post before i make this post… no luck for me…
getting help from you guys is my last resort
What was the problem?
When i knew my vesc are ok, i decided to clean the motor, when i open it, there is the problem, one of the phase wire inside is has cut… Just need to solder…
