hi,
1- i’ve two 300kv maytech motors from scramboards, something that worries me is the length of cables, the large ones are from the motor, and the short one is the sensor lead, this is safe?
2- if i want to build a all terrain board, should i use the sensor lead? there is any advantage than running the motor as sensorless?
3- it’s possible to connect the sensor lead to the Enertion’s VESC?
4- i’ve another ESC FVT 120A, 2-6S LIPO SBEC 3A/6V with a sensor port, it’s better to use two of these than two VESC ?
5- all the EMTB boards I’ve seen, are using two boxes one for the 2 ESCs and another for the batteries, if my motor cables are so large i can use only one box in the middle of the board? if this is a bad idea why?
6- if the motors have 300kv i need special settings on the VESC? (motor max, etc…)
thank you!
