Here’s a clip of the flex in my Rayne Anthem Deck. It’s a downhill-ish deck so it’s relatively stiff, but it has more flex than my other downhill decks. Is this too much flex for the Space Cell Pro battery and enclosure? @onloop@carl.1
Figured I’d post this here to hopefully give a public answer of exactly how stiff your deck needs to be for this. Thanks in advance!
Add some extra foam between the space cell and your deck and use some rubber washers when you attach the case. That will give you a good amount of extra play. Plus, how often do you jump like that on the center of your deck while riding?
