Yes. I have tried attaching 3d printed “magnet holder” on the shaft. That worked fine, but i think it could be more compact. For this i am trying to embed magnet inside the spur gear so i could save 3-5 mm of cover height.
Normal esk8 motor has 7 pole pairs and 3 hall sensors, so it generates 42 pulses per revolution.
42 pulses / 360 degrees. 1 pulse equals ~8.57 degrees of resolution.
Interesting design, I don’t think I’ve seen anyone with encoder integration quite yet.
Mountainboards and encoders mix really well, and I agree, I think embedding it in the spur gear is a good idea. Need some kind of retention though so it doesn’t break off and get in the gear teeth
Finally its working I made 10S6P Samsung 30Q batterypack for this project.
Vesc is limiting peak power to 3200 watts. Thanks to encoders torque is very high and constant.
