I’ve recently been missing a key for my motor shaft and I figured, why not make my own.
I’ve used PETG for the print and it held up riding around 30km now. I’m pretty sure it’ll hold up a whole eBoard life cycle. Its pretty simple to make but I think it’ll save you guys some time.
I’d be happy to make some on request too if you need special measurements.
My plan is to have dual motors with 190kv each + 10s4P ;-). I just print your keyway with a bit shorter in length 15mm, it fit my maytech motor perfectly. I guess that I will use combination of keyway, bolts and loctie . Thanks again for sharing it.
