So i finished my second built and i have a strange behaviour while braking.
i am using 2 vescs connected via can-bus. 2 ST 6355 190kV motors and i have 10S3P VTC5 battery pack.
Accelerating works fine without problems but when it comes to braking i have a strange behaviour - if i pull the lever back to start braking it all works very good, just the braking force feels very low. then theres a point that i reach - the brakes cut completely out and after 0.5 - 1 second the go full insane mode, at higher speed throwing one off the board. since the last build did not had this behaviour, i think its a vesc setting i am not aware of.
also, are these settings correct for this setup? never had a dual at all.
I would uncheck “enable traction control” under “multiple ESC over CAN”
Not sure if that is the primary issue but that’s my setting and has been working great for me
Do you have unusually long power wires to the VESC? Or some kind of coil in the wiring? Maybe there are voltage spikes due to induction that trigger maximum voltage and that’s why it won’t brake anymore.
