One of the hardest things when planning your first build is working out what components to buy and trying to work out what components are compatible with each other.
The new “Electric Skateboard Conversion Kits” (can anyone suggest a better name than this?) at Street Wing solve this problem, they contain all the essential ingredients, all you need to add is an enclosure and deck.
Testing the new batch of custom 6374 190 kV motors, now with sensor wires that connect directly to the FOCBOX rather than needing to use those fiddly converter cables.
Definitely!!! 12S is not ideal! Not only talking about the extra weight, but the power! ESC fail a lot at that point mostly for heavy people at steep hill! But i kinda like the speed at which this thing can be going
@stormboard1 - the motor you have has a different sized sensor cable connector than the FOCBOX, but fear not I always include an adapter cable.
Making those adapter cables is about my least favourite thing about Street Wing - they are silly fiddly to make, but thankfully that is a thing of the past now as I have the factory putting the correct connector on now.
@HighMasterGogo even worse than that, the male connectors are the work of the devil to solder up. I’ve got better at it but they are so small it really strains my eye sight, it’s not often that you wish it was JST crimping instead of the job at hand
The package will be dispatched tomorrow morning and should be with you the following day.
Apologies I didnt dispatch today but I left at 5:30am this morning to work with a special effects company building an electric vehicle for a movie and didnt get back till really late.
