Just a thought. Trick skaters imagine put a ton more stress on their axles than esk8 and they have 8mm axles. I think material (note: not grade of material) is less important than quality or even size.
They also go through trucks like crazy. I donāt remember anyone in my teen years having trucks longer than a year. Heck, I donāt remember anyone having a single component more than a year!
I would always wear my wheels out, my one friend destroyed trucks grinding on them all the time, and the other couldnāt go a few months without needing a new deck cause the kicktail was gone! Man, those were some fun days! I always preferred roller blades back then though
did the axle snap on those?
Nope. Maybe. I donāt remember ever seeing an axle snap. Bunch of bent ones and literally worn out hangars
Look at the surfrodz precision trucks that @psychotiller sells . Iāve only ridden them for an hour but they are the most stable at high speeds Iāve ever ridden. With 80mm axles they are hella wide too. I was carving like a beast and they were incredibly predictable.
Thanks Mike, They arenāt a solid axle though. That is one of his needs.
Ahhh, I missed that.
I bet theyāre a lot stronger than those beefcake trucks though!!!
Have you seen any failures?? Iāll keep them in mind for now.
Maybe try google. I havenāt seen or read about any failures with surfrodz. Ima get all googly now. Iām googling stretchy belts, Sasquatch and broken surfrodz tonight
Iāve never left a set of truck as loose, bushing wise, as i have these. Mondo carvy and stable at the same time, Iām really impressed with them.
Had to threaten my kid with a beating, he wanted them as soon as I walked in the house .
Oh and btw, this is not for a mountainboardā¦
Arsenal Cast trucks are extremely strong and come in 165mm and 180mm. 50 and 44 degree base plates are available, i suggest a 50 degree front and a 44 degree rear. The trucks take "Tall " bushings (around .75 tall)
the 180s work with a esk8 build? doing a jet spud freestyle board
@Alphamail I know this is an old post, but do you have any experiences with tall bushings on esk8 setups? Like the arsenal trucks you mentioned here, if I understand correctly you were involved in the design of those trucks? How will it handle sudden acceleration and braking forces from the motors etc. Any reason not to go for tall bushings in a esk8 setup? From what I can tell, the arsenal trucks looks like fun, carvy yet stable.
We were involved in some of the design aspects of the Precision Arsenals, not the cast as we would have done some things about them differently like duplicating the shallower bushing seat on both sides in place of a deep roadside and shallow boardside. If you are a heavy rider, tall bushings require you to run a harder bushing and as bushing hardness goes up, rebound goes down so you can lose some of the properties you like about standard .6" tall bushings.
