What’s the smallest deck + trucks you could use with a 6" to 7" pneumatic tires that won’t cause wheel or shoe bite?
Is there a “Mini AT” build out there that I can get inspiration from?
Thanks!
Thanks!
Sweet! Is that a jet spud deck? What trucks? Would you mind sharing your parts list?
that is an absolute masterpiece
yeah, that’s my board. I sold it early 2017 to a french rider.
@Darklinks : you can get my parts, works ultra fine and compact.
Deck - https://www.unikboards.com/en/boutique/board/ Bindings - https://www.unikboards.com/en/boutique/freebord-bindings-s2/ Trucks - http://www.trampaboards.com/vertigo-truck--12mm-hollowed--hardened-steel-axles-with-anodised-baseplate-p-11150.html Wheels - http://www.trampaboards.com/custom-superstar-with-65-inch-urban-treads-p-24912.html Mounts - https://www.unikboards.com/en/boutique/mountainboard-serie-motor-mount-trampa-infinityvertigoultimate-spring-trucks/ Belts - https://www.unikboards.com/en/boutique/courroie-htd5m-15mm-400mm/ Pulley - https://www.unikboards.com/en/boutique/15mm-motor-pulley-htd5m-8mm-motor-axles-keyway-and-screw/?attribute_tooth=15T Motors - 6374s VESCs Battery
Am I missing something?
Risers…to make the trucks work with the deck, need a minimum if 30 degrees.
that deck looks awesome!
