Hey has this ever happened to anyone? I feel like I over tightened the axel and now it won’t come out. I had to use a socket wrench with a hex to loosen it up. It turns freely, even by hand, but it won’t back out no matter how much I turn it, I’m guessing that the threading got messed up? Any suggestions on what I can do to remove it without destroying anything?
The grub screw mars the surface of the axle, the axle shoulder (non threaded section) gets stuck int he hanger, as you turn and turn the axle shreds the internal threads of the hanger. You end up with a hanger that won’t thread anymore.
Pro Tip: Don’t use axle grub screws in Surf Rodz trucks, loctite only FTW.
I spoke to her about a week ago about the shorter king pin for the adjustable base plate. I wonder if they’re in this week. I’m trying to go down to Florida for a couple of days to get out of this weather up north
