Guy’s looking to pick up a pair of Surfrodz RPK and really need some help with baseplate angles and bushings will be using @psychotiller mounts and Sixshooters mounted to @treenutter 44 …Could someone suggest a combination front and rear that is appropriate. Want to order as the 30% sales is on at the moment so timing is important…
Thank you @akhlut appreciate the suggestion…would do adjustable but because of availability need fixed at the moment…will be ordering the 80mm axles as well.
Im 215-220 lbs and i run 95.5a and 93a chubby barrel and a cone with their wfb formula… but honestly bushings vary person to person but the crank formula gets stuffer the harder u tighten it
I when ahead and ordered the RPK 200mm with 80mm axle front and back 45% figuring I couds always go from 45% to 50% on the front or just order an additional base. I also order hard barrels and will work with Riptide tuning once I have a starting point. It’s a killer deal with the 30% discount.
I have a tip for these trucks. Put some anti seize or long life grease on the kingpin just where it goes inside the base plate.
I had my front truck king pin totally seized in the base plate after about two months of use. I was freaking out that my truck was toast. At first I thought the nut was cross threaded or the kingpin was rusted. But the kingpin is stainless steel.
I had to put a 2 foot breaker bar on the end of the allen key and it made a god awful screeching noise as I turned it. Took me like 20 mins to get it out.
After it was out I confirmed it was not cross threaded, cleaned king pin and it looked fine, I think it was just road grime that got in there. From wet weather riding. The fitment between the king pin and base plate has zero tolerance. Which is good for precision but increases risk of seizing.
As well as grease, I also give my kingpins a quick half turn back and forth once a week.
I do not know how these trucks are constructed, but If the stainless steel is in direct contact with aluminium, it could be a galvanic corrosion making it seize?
