''Swing arm'' Steering mechanism for mountainboard..How? And would it work?
@Flexboardz Can you confirm that the diagram I had is the same basic mechanics that you were using?
Yes, it has 4 longitudinal swing arms holding the wheels with a link connecting the arm to the frame… (on the pics above, the arms are flexible and not on a pivot but the movement is the same)
So what are they made out of?
The arms and the whole board is made of fiberglass (it leans /steers like a flexboardz).
It is the ligthest proto I’ve ever made (2 kg w/o wheels) but I changed to regular swing arms after that…
I might have seen it wrong but did you use bushings where I had springs?
Not bushing on this proto but I used it on the next protos. I wanted to test conical washers as spring but never did it
Can you please clarify for us exactly how the bushing rods are connected to the swing arms and how they pivot with them?
What you see is the tension bolt (rod with bushing) who connects board frame and lower part of swing arm. The swing arm rotates on a crosspiece that steers when the arms moves up and down.
Basically, the parts that you see on the pics ( tension bolt and connection to swing arm), do not move when the arm moves up and down…so it’s the upper part of the arm who has to move back and forth and causes steering… I don’t know how to post video but you can find some image on flexboardz youtube page
Are you talking about this video? https://www.youtube.com/watch?v=MqQFQfdCsrk
The center part is connected directly to the baseplate and moves as such correct?
Oh so turning happens like in car right? Whole stuff turns right?
P.S. Is there any dampening or just plain wheel to board?
It turns like on a motorcycle at high speeds where the wheels lean to one side and it goes there. I don’t understand the double steering claim that they also turn similar to a skate trucks
But motorcycles has also problem with turning on low speed :smiley: I am curious how it turns on low speed, I don’t do track racing on high speed :smiley:
Yes, the crosspiece (who connects both arms) rotate to make the steering There is big a rubber piece between crosspiece and the baseplate which compress and give suspension effect (you can see the hole at the top of the crosspiece has oval shape to allow back/forth movement
Do you have any pictures of this board from the underside? Specifically focusing on the cross piece?
If I understood from your videos it does require bindings to be able turn right?
