Switching between different cell batteries
Im currently running 6s2p and was going to upgrade to 8s2p for a lot more torque on my 280kv sk3. Id need to limit the erpm since thatd give me too much speed, but if I was to switch between battery packs would I need to adjust vesc settings?
upgrading from 6s to 12s would yield a substantial increase in torque. upgrading from 6s to 8s is probably not gonna make much difference in torque.
You can however increase torque by increasing motor max current. I found that when I increased my motor max from 60a to 80a that it increased my torque noticeably.
Basically the Cutoff voltage. Just monitor your battery.
