This is art.
Here is a quick update. Received everything apart from the BMS, motors enclosure and fixings (hoping they come soon ) @fottaz - excited about my order from you!
Apart from that I have finished the battery off, wrapped the deck for a cleaner look, motor mounts are on, designed and printed some riser pads in solid TPU and also a custom xt90 loopkey housing. Pretty happy with how things are turning out so far!
Hello again builders!
Small update from last time I posted:
Firstly, I went to my local and got some grip tape and gripped the board up (this is always a good sign because it means the first carving session is close!)
Also grabbed some 100a duro bushings to mix into my mediums from surf rodz on my 50 degree RKP’s which has defiantly helped me find a sweet spot in turn-in ability and stability.
My order from Eskating.eu has been shipped which is exciting! Thanks @fottaz - you’re a champ!
Once this order arrives I will have some more pictures and thoughts to share.
Until then I will leave you with a few snaps I took of my old board next to it’s replacement
