Temperature motor
Hi
What is the max temperature motor for the sk3 192kw sensored you can set it up Like cutoff start and cutoff end
Thank you
Magnets and bearings are the top weakest points. I would say in general with any motor, 160F is the hottest you should ever hit. If they use good magnets and bearings, 200 is ok, but anything above 180F can permantly damage most magnets.
Does the foc box have a way of controlling motor temp or it being monitored by bluetooth?
Oooo really bc my motor heat up to 86c something is wrong for they heat like this My motor is sk3 sensored 192kw
You have it yes look at temperature in the tool you use
