Looking nice! The TB motors work great. Just be aware that some people have had experiences with the magnet retaining ring coming loose. Just be aware of the sound of the motors, if it sounds like something rattling around in there, it’s probably the magnet retaining ring. While it’s pretty easy to fix, don’t keep riding it like that because in there unmounted state they can break apart and potentially jam the motor. All the same, these are great motors, and the design is really good at sealing them.
Does anyone have a better option for mounting the motors that I am not currently aware of?
I would like to be able to not cut the end off the enclosure, but I would also like to mount the motors inside of the trucks, and have as much clearance between motors and the ground as possible.
Including the distance the trucks travel when turning, there isn’t enough room.
265mm belt (currently being used) is the shortest that I think will fit before the motor pulley and wheel start to grind together.
it looks like I’ll have to remove the enclosure starting at the blue line:
I have the riptide risers on my LY evo with surfrodz, the board still handles like it did without them. You wouldn’t be changing the geometry that much by putting a flat riser under the trucks (or just one set). If it was an angled riser than ya, you gotta do some thinking then!
