https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/1501?u=aretardedpillow Is that a fuckin hummie deck?
It was. It was indeed
Hummie deck was a drop?
Yes, It’s modified on my cnc to eliminate wheel bite.
I have the top link on the front for lots of turn ability and the bottom link on the back for stability. Its wicked stable at 32 mph but you can still do donuts in a small street with cars parked on both sides.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/1483?u=linny Woah, where did you get the motor vents?
Hello Linny these fans come from:https://www.stlfinder.com/model/sk3-63mm-motor-fan-cover-7TOPlmyv/8033943
they are not perfectly suited to the torqueboard 6380 but do the job anyway.
(make some changes) the drillings at the bottom of the engines are not identical and must be modified.
in action it sucks hard extraction and prevents impurities inside the engine and cools properly despite the design not expected for this engine
ideally it would be better to create a specific 3D file to this engine
have a nice day:slightly_smiling_face:
Might make a build thread about this soon. Parts are almost all here. https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/1521?u=niuva
They look adjustable
Yeah I fit them on the hummie deck while I still had it
That’s awesome.
Is that liquid tape?
You meen grip on the deck or? No there is no gripe tape or any grip atm on it.
No I mean al the white stuff on the connectors.
Its a silicone that sticks good to the Unity to prevent connectors vibrating free
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/1559?u=rusins
Oof, how’d you bend the truck so much like that?
It’s not. Weird angle… Crap phone
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/1582?u=rusins
That’s so pretty! Is part of the nickel strip covered by cardboard or is there some fancy way you connect the cells?
Nothing fancy just proper soldering, thanks for the compliments!
Seatbelts are a nice touch
