Slowly working on it, but this week I’ll receive the last part I’ve been waiting for the antispark switch from @goldenHusky and hope to finish it by the weekend.
Deck looks great with carbon fiber. Did you just use normal vinyl wrap that’d be used for wrapping cars? I’ve always wanted to try but was worried it wouldn’t adhere well to a wooden deck
Yeah, I used some leftovers from a car wrap job, in fact it didn’t adhere very well. I had to spray the whole board and wrap with urethane lacquer, now the wrap is pretty good adhered
Install nutserts and enclosure mounting bolts. Done
Install led light for antispark switch. Done
Install charger port. Done
Install motor mounts and motors. Done
Change the jst connectors from the motors. Done
Program the Focboxes with latest firmware and set up the limits. Done
I used these settings for each VESC, didn’t feel it too powerful but pretty good, I’ll bump motor max to 80A tomorrow
Motor Max 70A
Motor Min -65
Batt Max 40A
Batt min -25A
Fabricate a new 3 pin remote cable. Done
Install remote receiver. Done
Remove all bolts in order to add Loctite. Done
Sand keyway until it motor pullies slide in. Done
Test ride. Done
