Guy
April 18, 2019, 9:52am
1
Battery 24ah? or 24A output
Pretty big, what cells did you use? LiPO or Li-ion?
Andy87
April 18, 2019, 10:07am
5
those are nice wheels!
How hard it was to replace the shaft on the trucks and how the shafts now fixed? set screw and loctite?
Guy
April 18, 2019, 10:10am
6
will use lipo for this , I think there is enough space under
@bigben makes a dope enclosure for the spud. Much nicer fit. I can share pics in a little bit comparing the two
Guy
April 18, 2019, 10:14am
8
it was easy with the right tools … the axels pressed inside.
made flat area and pressed the new once with locktite and set screw holding it
Andy87
April 18, 2019, 10:15am
9
always but for somebody who just have some pliers and stuff it would be possible as well?
Guy
April 18, 2019, 10:29am
10
no way … you need press or high temperature to remove them , this area is the problem
Andy87
April 18, 2019, 10:33am
11
Thx for that info!
Now I also understand why one of my shafts came lose a while ago…
Guy
April 18, 2019, 10:44am
12
yes , in the titanium ultimate there are no teeth .
happened to me so I returned them with red loctite (can’t remember which … since then working great!
Gaza65
13
Guy
April 18, 2019, 10:51am
14
took picture for you to compare
8 inch on MBS matrix ||
9 inch with offset on trampa trucks
10 inch on my extended trampa trucks
Uh-oh, I’ve got ultimates. Should I be worried?
Could you post some pictures of how you removed the old axles and replaced them?
Guy
April 18, 2019, 6:50pm
16
no , I really love this trucks! and sorry, but it is too late to take pictures …
that’s what I wrote to one of the users here on PM
remove the set screw holding the axle
disassemble the lower part of the truck and remove all plastics .
apply WD-40 inside the setscrew holes
hold the axle with clamps
heat the trucks really good on the tip (place with the pattern
when the aluminum extend try to hold the trucks with heat resistant gloves and rotate+ pull out .
RyEnd
December 13, 2019, 5:20am
17
@Guy ! Did you ever get motors on this thing? It’s wild!
Guy
December 17, 2019, 7:43am
18
Sure , tested it with 3D printed motor mount and it was really great ! made CNC 7075 belt drive mount and pulleys but now working on 1:6 direct drive and 12S setup
Hello! Have you ended up your project? Yesterday I found this wheels on Ali and started thinking… An today by accident I find this topic =)
