DECK: MBS Retaliation BATTERY: 12S (2x Turnigy 20000mAh 6S 12C Lipo Pack) ESC: Focbox Unity MOTORS: Torqueboard 190kv 6380 MOTOR MOUNTS: Janux Matrix II Mounts TRUCKS: Matrix II (Hard Bushings in Back Medium in Front) WHEELS: MBS T3 200mm HUBS: MBS Rockstar Black WHEEL PULLEY: 72T MOTOR PULLEY: 18T MAX SPEED: 44MPH 18:72T | 46MPH 18:72T MAX RANGE: 20Miles
Swapped from Maytech to Torque boards Motors.
Designed and Implemented E-Loom wire hiders, I cant handle wires on the bindings.
Designed and implemented Deck shaped ESC case. Sick of seeing Box’s Esc cases FFS.
Swapped from Dirt tires to Metro board Rd tires, They are Thick and handle thorns without deflation.
Broke FlipSky Speedometer, To lazy to install Davega fully.
Installed MetrPro to track data and tell me info in my headphones of what the board is doing.
Geared the board for 50mph , first ride to test the 63T:18T pulley combo went well.
Did not hit any animals and got myself to a new personal record of 45mph .
Since my EMTB Build capped out at 44mph, It couldn’t ride constantly at 44mph.
I would just keep knocking on 44’s door, unless it was mainly flat.
With the 63T:18T combo I should be able to learn to maintain the 44mph and lean into 45mph+.
I do have a 2x Stormcore sitting here… but I kinda like seeing how far this Unity can go at 12s.
The only thing I dont like, is having lights mounted full time. Other than that, I would like to try out a mountainboard some day. They would be a nice addition to a street longboard.
The past case was more of a alpha test, to see if I could even make a case strong enough for my
daily abuse when riding. My board is not always on four wheels at the skatepark.
With that said, the mounting style of this case as well as the thermal’s and readability lead
me to making a version II.
