@Trdolan03 nice build! I will be separating the vesc’s from the battery box and moving them to the rear. I am hoping this will cut down on the box height. How do you like to Torque board 190 motors?
I have had 6 and they are all great. Edit: one annoyance is that the have a 10mm lip which makes fitting gears difficult. They may have fixed it as I have 2 motors that have a much shorter lip but I had to lathe mine down to fit direct drive.
@xclr8r inaugural ride went great. 16 miles was enough for me😂. I will definitely do a range test in the future. I had a flat which was annoying but luckily was right next to auto zone. So buttery smooth and tons of power.
Thanks. Straight from the Philippines
Got same problem … why let some 10mm out of the cage …
