The worst thing about them is that the thread lock doesn’t stick to ,I don’t know if because they are made of brass the curing doesn’t work as well as steel/aluminium
First ride using medium torque thread lock I lost 4 of 14 screws holding my enclosure
Them with high torque and high tolerance it’s holding so far, but you can feel that they are soft glued
Another great item to have is o-rings to put in some screws to prevent vibrations, such as the enclosure ones since sometimes you can’t really torque them enough without damaging the case
Great post! Wish I would have seen that 64 drawer screw organizer it’s exactly what I was looking for earlier today. Ended up skating home with a 24 hole organizer from harbor freight for $3
I’m using 2 sizes for my work with some techniques add to its effectiveness. Depends on the application. But I have come across some bulk but it’s expensive stuff by the pound.
This post is so helpful, especially everything having a link.
This is my 24-hole organizer from Harbor Freight, costs $3
My soldering stuff is in a separate case. A couple things I added that others might;
JST/SM 3pin/Dean’s T Connectors (For modifying commercial boards/parts)
Spare Speed Rings (Skateboard Washers) I purchased this pack for the Prime shipping cause I needed them for another board sooner, but 100-packs can be found for under $5 easily
