This is my first board i'm 170lb and small hills in my area I want your opinion
My budget is 580$ starting with nothing this is my parts list please give me some constructive criticism.
36T ABEC Pulley Combo Kit
diy-electric-skateboard-kits-parts/36t-abec-drive-pulley-belt-combo-kit/?attribute_motor-pulley=16T+Motor+Pulley&attribute_belt-size=280mm+12mm+Wide
Single Bolt On Motor Mount Set ONLY (Black)
diy-electric-skateboard-kits-parts/single-bolt-on-motor-mount-only/?attribute_motor-mount-type=63mm+Motor+Mount
TORQUE ESC VESC ® BLDC Electronic Speed Controller
diy-electric-skateboard-kits-parts/vesc-the-best-electric-skateboard-esc/
Turnigy B6 Compact 50W 5A Automatic Balance Charger 2~6S Lipoly
ZIPPY Flightmax 8000mAh 3S1P 30C Lipo Pack X2
Turnigy Aerodrive SK3 - 5065-236kv Brushless Outrunner Motor
FlySky FS-GT2B 2.4GHz 3-Channel Transmitter
https://www.amazon.com/gp/product/B00FS2U9BA/ref=ox_sc_act_image_2?ie=UTF8&psc=1&smid=A249WQMFP7W27G
83mm Pro Longboard Cruiser Wheels Flywheels
https://www.amazon.com/gp/product/B00I1WFKKE/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ABCX2RE03ARTE
Caliber Trucks Cal II 50° RKP Longboard Trucks - set of two
https://www.amazon.com/gp/product/B01NBF4574/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=AQ5JN7IFU4T3S
Volador 42inch Freeride Longboard ( Drop Through Camber Deck )
https://www.amazon.com/gp/product/B01MT0R7HH/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3V3VCB1EJCS64 $574.9 with shipping will this work?
for a single drive you really need to go with a 63mm motor. Preferably 6374
Generally, the VESC is best if you use 10-12S. A very well proven and common setup is 10S with a 190kV motor. Since you’re using a single motor and have a few hills, the bigger the motor the better. I’d go with a 6374 190kV motor if you can find one since its pretty much the biggest motor you’ll be able to get and it’s the right kV. Those changes would give you significantly more power and cooler performance.
That would give you a top speed of roughly 40km/h. If you don’t need this much speed then I’d consider going with a 13T motor pulley cause it would give you better hill climbing with a little lower top speed. Since pulleys are so cheap I’d get the 16T and 13T and see which one you like most.
Also, drop through decks aren’t the best idea since you’ll need as much clearance as you can get for the motor and enclosure. You can get cheap blank decks here if you’re on a budget.
ty for the intel
For a single drive running 6s look at DIY’s 260kv 6354 motor,. One of my builds is using this motor and x2 8000mah 3s Zippy lipos. It’s no speed demon, but it does a good job. I get about 11 miles and 18mph.
My build log is in this thread, shows all the parts and the math behind​ the values.
Turnigy 5000mAh 5S 20C Lipo Pack i got 2 of these
Turnigy Aerodrive SK3 - 6364-190kv Brushless Outrunner Motor
change motor for this
http://www.skateshred.com/index.php/40-split-tail-canadian-maple-wood.html new board
if i did my calculations right with shipping its $542.96 if there is any thing else to change please tell me
The setup is good. Just don’t forget the small stuff. The VESC motor wires are 5.5mm bullets while the SK3 motor wires are 4mm bullets. So get the connectors you need and find/get a soldering station to change them.
I (at 170lbs) ran a single drive 6364 190kv 9s for 6 months in college. Was perfectly fine with it. Make sure to purchase protection gear as well (at least a helmet). Get loctite (Home Depot/Amazon).
TLDR: Your setup looks good!
