I’ve got these, haven’t been able to properly test them though. I’m planning on running them on 10S. I’m hoping I’ll be able to put a decent amount of motor amps through them without overheating but we’ll see. You’ll probably be fine at 20ish battery amps per motor so I wouldn’t worry about having a crazy high discharge battery.
The mounts are kinda annoying since they have no way to adjust belt tension so I may end up filing them out a little. Also there is a spacer between the wheel bearing and the pulley bearing and its inner diameter is bigger than the axle so it rattles around and gets really annoying. I ended up replacing it with a regular bearing spacer and some washers to make it long enough.
Also, the kingpin bolt isn’t really long enough for most bushings so I swapped out the baseplate to a caliber V2 one and now I’ve got some blood orange barrels on em since the bushings them come with are complete garbage.
I also swapped out the wheels to 83mm ABEC11 Flywheels and the axles are barely long enough to fit them, I had to remove some washers to get the nut on far enough so we’ll see how that holds up.
I may end up rewinding them to change the kV cause 270 is way to high for 10S but they might be able to put out the kind of power I’m looking for regardless.
Depends on which cells you’re using. As far as I know there’s no standard for testing safe discharge rates. Li-ion cells ratings are usually pretty accurate, however the same can’t be said for lipos, especially MultiStar. People usually assume they’re good for half of what their rated for. But yeah I’d shoot for around 60A.
