I have one I will try , thanks
If it helps, I had to use a servo tester that had the pot dial on it.
I did it differently by soldering the signal wire to the middle pin on the pot if I remember right. Then I adjusted the pot to zero out the signal between forward and reverse.
Mate thanks a lot I fixed it
Right on!!! Good job
