Today was the first time I rode my board with a VESC and my homemade Samsung 25R 6S4P battery.
Last summer I used a 120A hobbyking ESC with 4x 3S 5000mah 25c lipos (6S2P) which worked great. I could climb any hill basically and I never ran into any problems.
But after riding today I could barely climb any hills, nor accelerate very fast. If I did the VESC would just shut down for a few seconds and then be good to go again. I didn’t even need to reconnect the remote.
I believe that the VESC in combination with the 6S battery requires more amps than the VESC can handle. It’s the same Motor - SK3 6364 245KV with a 16teeth and 36teeth pulley system. 83mm wheels.
I’m thinking, maybe I get away with just changing the gearing to give more torque and lower top speed. Or should I just bite the bullet and upgrade to something like 8S/10S?
If anyone can spot an error in my BLDC TOOL settings that’d be great though.
Probably voltage sag - the 25Rs are known to sag quite a lot. 20V as cutoff values is too high.
You should go to 3V per cell for start and 2.8V for end values.
the 25r are rated for 2.5V - 2.8V will give you some healthy margin. Also this is for cutoff end - which you should only rarely reach.
3.3V is for Lipos - they have a totally different discharge characteristic than 18650 cells.
it does - but if you are going to drain the battery at 60A then you will still get the sag in one cell as if you drain 15A in a 1P.
Sadly it didn’t make much of a difference, though I did notice a small improvement. But it is not really as it is at the moment. It’s far too weak.
Makes sense @Maxid ! Thanks for trying anyways I think I’ll wait and see if someone else knows what might be wrong, if not I will probably just rebuild the pack to a 8S3P.
For continuous use yes - but you are not going to use that. For short periods uphill it could help though. The temperature cut-offs will make sure you don’t use too much.
That’s what Vedder says:
“Absolute max” is checked in every PWM switching cycle and used in case the soft back-off strategy for the other limits doesn’t work. I usually set it way higher than the other limits because soft back-off is preferred rather than switching off the motor with a fault code, but it should never be higher than 150A.
The “Slow absolute max” box will make sure that a filtered version of the maximum current limit is used. This is useful if there is much noise and that fault code kicks in all the time. I usually have it ticked.
So i guess it will not make a difference in your case
you don’t need firmware to get consistent power output you just need the right ratio of batt to motor amp settings. batt amps allowing more power at high speed and motor at slow speed. Motor amps aren’t true amps but just the amperage that would be on for a fraction of a second and when put in the full context of the second it’s much lower…depending on the duty cycle. so setting to 150 motor amps you still won’t go above 80 real amps if you set the bat amps to 80 and you can have extreme acceleration if you want it. INfact it’s the only way you can get to 80 amps on the lower duty cycle lower speeds…doing much higher motor amps
