I have an important update regarding Torqueboard 180mm 50 degree V2 trucks. There appears to be two different versions of these trucks out there and the V2 I received above has changed without an official announcement of what might be called V3. The pivot cup hole in the V2 is around .630 or just over 16mm, the V3 version as about .700" or 17.8mm.
V2 pivot cup is our Indy V3, we do not have a pivot cup to fit this
Please do not order unless you can confirm with calipers the diameter of the hole in your base plate!!!
