I just picked up two used TB 12s ESC’s, one sensored and one unsensored, from a fellow member, and I’m having trouble figuring out how to program the sensored one using the TB programming card.
Is there some trick to programming the sensored esc, or get it to connect to the programming card? I was trying to use the bec from the non-sensored esc (powered by it’s own batteries) to provide power to the programming card since the unsensored unit doesn’t have its own BEC yet, but I can’t seem to get the sensored esc to connect to the card and display the menus. I got the non-sensored esc to work with the programming card easily, using the same BEC, so I’m a little baffled by the sensored one. If it makes a difference, I don’t have a sensored motor or sensor wires, so I’m just trying to get the sensored esc to run unsensored, and access the programming functions. Also, the sensored ESC works fine all wired up and using the BEC to provide power to the receiver, so I know it’s functioning properly and the little LED lights work. I just can’t program it.
