So as most of you guy know TB sent out replacement clamps for all those having issues with their current ones… Now im a bit confused about the shape of the new Clamp and the contents of the bag haha…
Can anyone else figure out how to make these work >_>
Uhm, flipping one of the clamp parts doesnt work? I think the black thing is a shrink tube thing to shrink on to the threaded part of the screws. So they dont vibrate loose?
I am not 100% sure, but i think you are supposed to shrink them on the threaded part of the screw, so they will act the same way as nylock nuts. @torqueboards should know?
They told me it was to place in between the hanger and the clamp to fill in any empty space. I did not use them and the clamp did bite down and grip the truck properly so there is no movement and the mounts are easy to center, no more cock eyed mounts lol
This set up is the best set up so far, for my set up though I would need longer screws and spacers to make the idlers work they don’t stick out far enough for my set up.
I use shrink tube just like that on the old mounts. A peice goes between clamp and the hangar on the hangar faces opposite from the motors.
It seems they wouldn’t really be needed anymore with these new clamps, but they couldn’t hurt to cut long ways to open up the tube, wrap the shrink around the hangar where you are going to put the clamps so each tube opens up to line up with two faces on the hangar matching half a clamp each and clamp down over the shrink tube. They might stay on tighter this way due to the resistance of them pushing out on the clamp instead of bare metal to metal, and even provide a bit of damping for the vibrations through the mounts to the motors because of this small bit of extra resistance.
I can’t imagine these are to shrink onto the screws… Just use some blue loctite and let it cure after torquing down the clamps… Assuming these clamps are threaded.
Also, props to @torqueboards for great customer service following up like this with customers having issues with products.
