Remove the motor pulley while doing detection. make sure nothing is rubbing like the shaft C-clip on the mounting plate.
If your using a sensored setup, try unplugging the sensor cable and see if it will detect without sensor.
You´re running 6s lipos?
Check if nothing is shorting inside the motor. How long are your wires and how long are your motor mounting screws? (the last guy had the screws too long, they touched the windings inside and so his detection didn´t work properly.)
@TarzanHBK Yes I’m running 6S. WELL DARN, the provided hex screws from the @torqueboards 50mm motor mount kit caused this. I unscrewed them so that the motor is freely moveable in the mount, retested the motor detection and walla!
Now I really think this caused my last torqueboards motor to fry, cause the tips of the motor mount screws were charred!
Now I need to find a way to sand down these hex screws…
@gottagoslow I think this is a specific issue with the 5065 since it’s a smaller motor. 63mm doesn’t have this issue but thanks for bringing it to my attention.
