First build. Already got the bare board setup for now. Trampa board, Vertigo Trucks, 8in Wheels, Straps…
For electronics I was planning on 2x 6374 Tunigy SK3 190kv 4x 6s 5000mah batteries wired in series and parallel to make 12s 2x SJ Hawk 120 Amp 12s Escs 2x 9pack YGE Cap Banks
Id like to get 55-60 miles per hour on a belt driven setup. Can you recommend suitable drive ratio/pulley sizes to achieve this? I can build the motor mounts/pulleys out of aluminum/steel with cnc.
Also due to the speed, any recommendations on battery C ratings? Heard about the 9 pack YGE caps from Etoxx video 65kmh(40mph), does well with the Opto 12s Escs to prevent fire.
Im willing to change/upgrade the escs/motors to get to that speed but Id like to stick with a 12s setup and belt driven if possible.
Im 155 lbs and was thinking (24t / 72t) or (22t / 66t) pulleys may work
Any ideas/suggestions? The battery C rating still confuses me when I change the numbers though, so am open to advise, thanks.
