Could anyone do a member a solid and make a paper template for me out of the top surface of the HolyPro?
I need to drill the truck holes with an older model 15 ply board which is also 35degrees (kitesurf probably)
I would also like to have a shot at trimming it down, Trampa says I will or could fail, but I would like to try, I have a jigsaw/holesaw and reasonable sense of humour.
You know just get a kids crayon and tape down a piece of paper then start wiping the side of the crayon on it, you know like old gravestones, doesn’t everyone do that?
What do you mean by the “top”. The top of the hanger or do you need the truck mounting holes? If you just need the mounting holes I can draw you up a printable CAD sketch of them
If you go to our website (desktop), go to a vertigo truck, click on the manual tab you should find what you are looking for. Template 1:1scale, PDF format.
You have any luck with this @banjaxxed? I’ve picked up a second hand mountain long board and much prefer the HS11 tips. Was thinking of taking a jigsaw with metal cutting fine tooth blade to it.
The two seem to have very similar truck holes so I could get away with it.
