I’m updating my e-board for something that can deal a little bit better with anything but smooth road and I tested 7 inch tires on a cheap kiteboard. That gave me the desired off-road capabilities but the steering was super hard and the board heavy and unwieldy. I’m now trying to consolidate the benefits from my longboard with the offroad capabilties of those 7 inch air tires.
Has anyone ever tried mounting a Trampa Mini Spring Truck on an ordinary longboard? Do I need the angled ends that their carver board has? Can it fit 7 inch tires on a longboard deck?
I suspect that the main difference is in the handling. The minis probably have better carving ability and tighter turns due to the axle length being shorter.
The full size trucks probably have better stability at high speed.
There is some overlap in ability since both types can be set up to your liking using the proper bushings or barrels and springs.
Yeah, you are of course right on that, but since I’m merely prototyping to figure out what I wanna end up with, 3d printed is probably a good start It will break pretty fast, but a test ride is probably doable.
No problem with authorities so far. It’s an aesthetic thing if you ask me. I passed by some cops in a couple occasions and they complimented my board instead
