I wasn’t going to post a buildthread, but i figured Swedens first trampa should have a thread
This is my first DIY e-board, I currently ride a Carbon GT which was starting to become a bit boring and after reading this forum for a couple of months I decided to go with the Trampa.
And that’s how far I’ve gotten so far, waiting for some XT90 connectors for Parallel and serial connection of the batteries. I should be up and running in two weeks.
For future reference, the Loctite 603 and 638 is pretty much the same. 638 is a bit thicker and more sensitive to contamination such as oil when it’s applied but works on a wider gap span.
@Yecrtz You should get it, the build quality is excellent and Jens has great support if you need it. And it looks awesome
I have no idea what the range will be, this is a 8S2P configuration and not really made for range. I’m hoping to get 30 minutes of hard offroading. Haven’t calculated the top speed but probably 35-40km/h.
Wow that is crazy never heard of only loctite.
I wouldnt trust it not to spin around the shaft with so much torque on my mountainboard.
I feel better with set screws and loctite together.
@sMATTEr I have plenty of broken motors who’s stator came loose from its press fitting with loctite.
They never last long. The only motors i have still alive are sk3 because they have 3 screws holding the stator from spinning.
@Nowind have you marked the shaft and pulley and checked if it moves even a little after a ride?
You are ofcourse right, I would also use a setscrew and Loctite but because of the weird motor design this was the solution I chose. I’ll mark the pulley and gear up and see if it moves after the first ride.
Had a nasty crash last night, broke my Ruroc and fucked up my back pretty good. My wife freaked out. So. I’m selling. The board is in pretty much mint condition.
