I look forward to seeing how you manage to fit all those batteries to the board. Are you thinking top or bottom mount? I’m going with a 12s7p bottom mount on my Kaly, which is quite similar
Is this sarcasm or irony or that your post is meant serious. It will be a project for the next year and I wanted to collect some Opinions about my build plan. I’ll print the enclosure stuff myself.
@anon64938381 The pack will be top mounted. 80 cells are alot. I’ll be going for 30Q or VTC6.(Not quite sure yet). And for the bms, it will be a charge only.
Both.
well the thread had literally 3 sentences when I posted, no list, no nothing.
If you want comments try to specify what you expect in terms of performance such a range, speed, current draw, where you intend to use it, etc.
Then it would be easier to fingerpoint to where there might be a flaw or not.
That is my expectation for the speed of my build. For the range I expect 50 km of range and I will shred mostly of the time through the woods and sometimes on street. Black Forest FTW. From this pack I could draw 60 amps per motor.
