Has anyone got any new or second hand trampa 12mm skate truck for sale ???
I haven’t but if you want it for esk8 I would recommend channel trucks, I’ve read several times that skate trucks (with bushings) shall not really be the best for that,
Its for an electric skateboard that i made but i want to put mountain trucks on it so i can put propper tyres on this the 20050 ones as where i live the only way to describe the road surface is s**.
Ok, understand. If you are not going too fast it could work. But you should use angled risers for proper steering (15 degrees) but if it’s a skateboard and no longboard you can mount it at the angled ends. Maybe the cheapest is to buy a used mountainboard on ebay and use the trucks and wheels. Good Luck!
No its a longboard i thought i might need a rised angle thingy but i have same motor and similar gearing and speed controller ect on a scooter i made and that will do 40mph.
40 mph with MTB skate trucks hope you wear some safety gear
I just say speed wobble…
Yeh doubt i will need to go that quick my board does 30mph atm and i get no speed wobble but the vibrations make my legs go numb after ten minutes
You have a long board and just want to be able to run pneumatics?
If thats the fancy term for the 200*50 tires with innertubes yes
just means full of air (under pressure) or gas bro
Thankyou for helping
Who sells these as i can not find them anywhere
If you are after Trampa gear, just buy it direct…
and if you are after angled risers @okp is about to get some made up. Search for his thread.
Will do thankyou i spent ages looking for them on trampa but couldnt find any
