Hello, I am going to build with a Trampa Solid Carve Deck and I would like to create a 3d model of it to design my own battery enclosure, either 3d printed or out of fiberglass and I was wondering if anyone could tell me the dimensions of the deck are or if anybody has a model already designed up could you post the file on the forum?
I had seen that on thingiverse, I liked it a while ago. I wanted to design my own based off of the components I am using.
Im Confused
It fits the same deck. The HS11 is 200mm at its thinnest point, and the carve is
around that as well.
Heres the enclosure from eboosted that I was going to buy for my Urban Carve.
8 cells = 144mm
Assuming theres at least a cell of overhang for you to bolt your enclosure down thats looking at around 184mm, and then add the extra horizontal interior space needed for shrinkwrap and fishpaper. +10mm
~200(slightly more than 194mm) in total, so you can use it, or even print your own version of this with a slightly slimmed down waistline.
or you could even ask @ eboosted himself
Thanks for the info
you can always find some more details about the deck dimensions on the trampa home page under HQ and than manuals or somewhere around that.
I will do that
Sorry I had not explained well enough, I was wanting to make the lowest volume enclosure, i wanted to see the angle of the deck curve for the Trampa Solid Carve Deck. I wanted to conform a enclosure to the flex of the deck and needed some more measurements than what is on the Trampa website.
