hi guys, first time here, here’s a weird one : I’m putting my (Trampa) Spur Drive board back together, but whenever I’m screwing in the 4 motor screws all the way, the motor is not turning anymore, like if the screws were going too far… (pretty sure it’s even touching the red coil inside the motor !)
if I unscrew them for like 2mm, motor is turning again…
pretty sure these are the screws I got the board with : https://trampaboards.com/m4-x-25mm-socket-capped-head-torx-bolt-iso-4762-marine-grade-stainless-steel--p-26718.html
it’s probably so stupid, but I’m stuck, thanks
