I am from Swizerland and i build my first elektric Skatebord.
My deck i have is a Trama street and urban carver.
At the moment i driv it with the Trampa motors with 118kv and two Alien Power 6S 10ah 35C and two VESC 6.14.
Now i want to built a baterie pack in the underbord batterybox.
In the past now i think my batherypak with 12s 4P are too small with 40A for two motors.
May i put on the APS Motors hwo runs with (6374S 170KV 3200W) 800Watt mor than the Trampa ones but only on 10S, so they drive even on more amps am i right?
So then i use the oder 50 pice in a big portabel speaker i build.
And my other question is wich BMS is the best for me?
How can i get an DieBie BMS? (May two i want to build an ofroad board too. with the bigest Motors i can fit on the Directdrive etoxx Mounts.)
I dont know about the quality of the iJoy, but I will suggest you to go with Samsung 30q (20A 3000mAh) or the Sony VTC6 («35»A(more like 20) 3150mAh). Both these are 18650 cells, in these are what about everyone here use
iJoy seems fake, huge discharge and huge capacity…
I would go with the standard 30Q cells, much cheaper almost the same mah if you put one more in paralel
I would suggest a bestech bms or the diebie bms, bestech proved to be very good I think that the diebie one also did
For one 48G battery you can get 3x 30Q ones… much cheaper to go with 30Qs
Also where do you live, I visit Switzerland all the time
12s5p is a big battery 650wh
That bms seems really cool and compact
It claims huge numbers and has some great freatures, I would do some research on it
But also you can save some money and get the bestech one and a bluetooth module for about half the price
I do not think, that i can build an BMS by my self. without spending muney for broken parts and stuff for build… hahah
I can wery well weld every kind of steel, without a problem. I do it every day at work.
so i make the endings of the baterybox out of aluminium and paint it red.
Can some one tell me how this work, when the VESC charch the batery with the Tiny BMS s516 - 150A/750A?
This BMS has seperad Load and Charche inputs.
So when i brake the batery will be charching without balancing? Or is there a problem for the BMS when there come electricity back in to it at the Loat ports.
There are meshuring abaut the iJoy 21700 should i trust them?
