I’ve been unsuccessful getting the motors to turn tho. I’ve got everything hooked up, bms correctly installed, and power to the vescs and to the receiver. What else am I not thinking about?
How is it going?
Hope you will fix your batteries in the tray and planed to cover the nickel strips as min with some battery tape. Like this it’s big risk that you short your balance wires sooner or later.
If you not sure with your vesc settings, upload some screenshots and we can have a look if everything is how it should be.
i always run detection multiple times on same values to be sure it wasnt a fluke that the detection was successful. How much amps did you set for motor and battery?
