I’m looking around now for 18650 batteries, and hear Samsung ones are pretty neat, and are a good way to go. I saw these on Aliexpress for a pretty decent price (8 pieces fo 20 USD) but thought it may be too good to be true. Are these sketchy?
If these are dodgy, where do you guys recommend me buying bulk for relatively cheap, I have $400 to spend on batteries for a Bigfoot 160 monodrive build.
Liionwarehouse if you are in US. I am going to get my cells from FastTech (I am in Australia) they have good reviews but the cells ship by boat so it takes like 1-2 months.
Edit: Forgot to ask, are they cheapish? I’m on mobile and not enough time to check right now. I have around $400 AUD to spend on batteries, hoping to have a little bit left maybe a bit less than $100 to spend on enclosures and extra bits.
5.2A discharge rate. Wouldn’t be suitable for eskate unless you had about 10 in parallel, so you’ll probably want to look for a different cell. Also, I wouldn’t trust the legitimacy of alibaba products, but that’s just me. Try the Samsung 25R like Enertion uses.
You mentioned you were getting it from FastTech? When I check out it says Australian Expedited Air or something? 9 days in transit, or something along those lines? No option for shipmail, unless that was the one.
I have ordered hundreds of cells from them and every single one has checked out. Not a single dud. The more you buy the less they cost there too.
Also they don’t waste time getting them to you. You’ll probably have them in a week.
I use the Samsung INR18650-25Rs because they’re basically made for our applications at a 20 amp continuous rating and a 100 amp burst which is ludicrous.
