Hi, this is the first time I’m building an electric skateboard. I’m on quite a tight budget and I am trying to buy all the parts from Hobbyking, because they ship to South Africa. It is almost impossible to find a VESC in South Africa and most websites that sell VESCs don’t ship to SA. Will this work well or should I consider buying a much more expensive one that ships here? https://hobbyking.com/en_us/turnigy-sk8-esc-for-electric-skateboard-conversion.html?wrh_pdp=3
I am going to be using Li-Ion 18650 cells (3.6v). They are generally between 1500 and 2000mAh. What results should I be able to expect with a 10s8p setup?
The Ebay esc’s come with remotes and are solid and reliable. Not very adjustable, and only good for 25 amps/motor (not enough to make 6374’s worth it really) but they’re the cheapest way to start that I know of. I think it’s around $40/shipped for the single and $70 for the dual
