Up for grabs is my latest build.
I find the deck a little short for me so I’m building a Landyachtz Evo.
Here’s the build in a little more detail.
I’d like to sell as a complete but would consider selling the deck, enclosure and power pack inc bms as a unit.
Then I can build up the raptor deck from secret Santa with the drivetrain.
I’ve not used it much so it could be considered nearly new.
3 cycles on the battery and wheels still shiny.
It’s super quick fun little board. Set up with 15 tooth 32 at the moment so I’ve never been close to top speed.
For the brave it should top 30mph.
I’m based in Dorset UK.
Hi,
I’m in the UK. I don’t want to break it up just yet unless someone wants the deck and battery pack/enclosure because this wouldn’t suit my next build.
I knew I’d forget something when calculating…
Forgot motors in my calculations… well over £1100 build not including connectors and wire etc… oh well.
Price still stands at £850.
I like that one very much!
Does the enclosure fit the Cantellated Tesseract?
Can you tell me which motors, motor mounts, pulleys and belts you used?
Trucks are 50° base?
PS: no offence, but you should think about using bushing that fits your weight and riding style instead of tighten the stock ones up that much. This would be the proper way to adjust your truck
Hi @Luuke,
no offence taken. Mr seasonal postman has lost all trace of hard bushings… I need all the help I can get though.
I have no local shop to talk to or no crew to mix and match what works and what doesn’t. So suggest away…
I pinged an email to Loaded a few weeks back to see if the two decks were made on a similar mould but they never got back to me. They do look a pretty similar shape.
The trucks are 50’ base (calibers), the mounts are enertion clones, belts currently 12mm but have 15mm coming.
15mm steel pulleys bearing loctited to the shafts. Wheel pulleys are alien power systems 32 tooth aluminium.(15mm) Motors 6355mm unbranded but I think you’ll recognise them in quite a few of the esk8 vendors.
@taz Raptor 1 without battery. (Dead cells)
10s bestech charge/discharge bms.
12mm 36teeth pulleys. Abec and kegel.
97mm abecs
10s, 12s tiny bestech BMSs without balance!
Enclosures for many boards.
And my mind goes blank…
