No stock but I have moulds for a lot of boards. I make them on demand… (a little after demand)
Ben, why not make a list of the boards you make enclosures for?
As @taz already said a list of enclosures would be very helpful. With measurements and everything. So one could estimate which one to choose.
That would be greatly appreciated
Landyachtz Evo 39/falcon 40 single
Landyachtz 9two5 single and double
Landyachtz switchblade 36 single
Loaded Tesseracts single and double
Earthwing supermodel double
Tayto/spud single
Hummie decks single and double.
There are more in the offing but getting round to them when I can…
How much would you charge for a Tayto double ?
How much range do you need?
I`d like to have dual 6355s with quite a punch so i would think 10s4p ?
I have dual 6355 with 12s3p and they are quite scary on such a small deck.
IMO you do not need any more power in the Tayto but ofcourse your case might be different.
Hi, Sorry I don’t make a Tayto double.
oh, what is the range you are getting ?
Damn, is the spud DS enclosure compatible with the Tayto ?
Approx 30km
Wow that is more than i thought. Do you love the riding experience with that build ?. What would you Change if you started a build from Scratch with that form factor ?
Yes it is
Nothing really. The only things that I would (and I will) will change is the wheels (I have some 77a caguama on the way) to make the ride softer and some e-calibers so I can run 12 or 15mm belts.
Awesome. Thanks for the Inspiration. I will probably have almost identical specs. Though i am aiming for a 10s4p build. I just need the range.
You will have to get creative with the battery layout. I think a very good solution (possibly the only one) is to use the layout @eboosted used on his moonshine sidekick
Even if i would build it double stacked ?
Not in that case. If you can fit it in a single stack enclosure why go double stack?
For me the Tayto is a small deck that I chose to build it as light and portable as possible. There are a lot of better decks if you want to go for range, speed etc.
