Hi guys, I have just come back after being away from my board for about 6 weeks. However when plugging it all back in the xt60 connector starts to burn and turn red. When I check my cells one parallel group of cells in my 10s3p pack is at 1V.
I have previously had to replace a group of cells in my pack due to them discharging more than others and causing the BMS to cut out while riding.
Ok, thanks for the help. I’m gonna have a proper look at the pack. And remove those bad cells. I wanted to spot weld the cells but I was on a tight budget. Cheers
I can’t reccomend welding your cells enough. I understand about keeping costs down, but when your pack shorts and you have to buy a whole new board… It doesn’t end up being cost effective
