So After todays ride I opened up the enclosure to monitor my cells before charging them up to full charge again. All cells read 3,47 volts measured on the BMS balance wire connector. To be able to measure the first group of cells without stripping the battery I put the negative probe on the charge port -.
I charged the battery up to 42 and re-measured the cells.
HORROR!
First group of cells read 3,89 v. All the others were at 4,20-4,22
Faulty cells? Time to buy new cells? Disassemble battery? Lots of work? Fire?
So, I started searching the forum and read everything I could. To no good, cells were still at 3,89.
Time to strip the battery. Shrink wrap, foam, fish paper, kapton…
Inspected nickel welds. Rock solid. Checked soldered balance wires. No problem.
So, then I measured that first group of cells again. Probe directly on nickel this time. duh
4.20!
Phew!! Funny thing is that all parallel groups showed the same exact voltage pre-charging while measuring at the same spots - charge port and balancing connector, but post charging (while BMS was in balancing mode I guess) measuring through charge port gave a lower voltage reading on that first group of cells.
That is good news. It’s good if you are a bit concerned about your batterys health whether you built it or not. I tore apart my battery after the PSA: Be careful assembling Li-ion Battery packs thread. Thankfully all was good. The charge would be a bit slow at 1.13a. Now I want to go test my power supply
Yeah. Those threads are scary. Since reading about one of those fires, I always charge my board either outside or next to me. Never overnight or unattended.
Charger was one of those $7 off ebay. At least it doesn’t put any stress the battery…
May I recommend a boost converter cc/cv charger? I was looking for an adjustable charger for my 10s and 12s packs and was reading the thread about using a 60v psu and step down power supply, but 60v psu are a tad expensive. I then googled cc/cv boost converters first one that popped up was a 600w 12-80v converter for leds. I got that and a watt meter to see current and voltage and connected it up to a 12v 15amp psu I had laying around, it worked but only charged at about 1.5a, so I got out an old adjustable psu cranked it up to 24v and I now have 5a at 50v for my 12s pack. Hurray.
