Took a few months, fried a drv chip, but it’s finally complete
I wanted to achieve the cheapest setup with as big of a range as possible. I decided one motor would be best for price and range. Chain was for durability, as I plan on riding on the occasional trail (we’ll see how that goes). Originally I had the motor facing the outside, but it kept hitting the kingpin. Turned under the board the motor mount hits the deck under hard carving, but some risers should help with that. Since the trucks taper, I had to grind the spot where the motor mount attached.
Probably the quickest crappiest enclosure, but if it works, it works. It’s the box they shipped the batteries in, it’s cardboard and flips around so it opens and closes easily.
The batteries are lipos, one 4s 10ah one 6s 10ah in series. They charge separately with my imax b6. Pita, but cheap
Motor is an eBay 6364 at 245kv. At 10s, I go over the erpm for the vesc, but I’m geared for speed so I’ll likely never hit it. Gearing is 11t motor 32t wheel on 100mm wheels. Definitely a kick start board
