Itâs stated that two escâs are used, one for each motor. So technically theyâre running at different voltages. My question is what if we had a single motor, and then could gear for low speed like zero to 15mph, maxing out our motor to the highest voltage, then switch to a gear that allows for top speed, like 15mph to 30mph? Wouldnât that make it quicker?
Donât get me wrong, I really appreciate your work and your thinking outside of the box.
And then getting it done!
Just tried to figure out in my head what is going on. Brain experiment before real life experiment.
And one thought in my brain is:
When your 200Kv motor with 70mm wheels and 2,5:1 gearing goes 37km/h it produces a voltage of around 37V and the ESC needs to be able to cope with that. Not many amps because there is not much load, but 37V.
Obviously your ESC is able to cope with it. It works, great!
the UDR concept has come up again about 3 times this week so I thought I would update this thread.
the other day my friend and I were skating (he was on the UDR) and we had a bit of a drag race.
the UDR board KILLED it! like I was embarrassingly out accelerated.
I peaked at 36km/h and he just cruised away effortlessly.
Thanks for pointing me back to this thread. Trying an uneven drive combo of 190kv enertion 6374 rear and 245kv Tacon Bigfoot front but on 12s. Think the uneven helps with the 245kv on 12s or still Erpm max issues with vesc?
That is a good point! TB esc should be able to handle this at 10s, maybe 12s? Was thinking too vest-centric. Anyone used TB esc for 245kv on 12s? @torqueboards ?
Good point, I actually got the 12s batteries from @oriol360 and was super satisfied there. Did not think to check his esc for 245kv on 12s. Maybe that or TB for sure, awesome!
well I went out today with every intention of filming the difference between a Dual diagonal 280kv twin and the 280/430kv uneven dual Rear drive.
unfortunately my friend left the nunchuck behind so we had 2 boards and 1 chuck.
so what did we do?
I grabbed a big stick and gave my mate the only chuck and used the stick to tow me along behind the UDR.
so I guess we tried a different type of experiment. the UDR can successfully haul ~170kg of human flesh up mild inclines.
I know dual TB 12s escâs work fine on 12s with TB 230kv motors up to 31mph. I rode two pretty spirited 13 mile and 15.5 mile tours on that setup the last two weekends, and it worked perfectly. When I finally finish my mountain board, Iâm gonna run this same setup or go with a 245kv SK3 & 245kv Tacon pairing. I guess Iâll find out if they both are really 245kv.
