I have updated the design of my ESK8 riser which objective is to act as an interface and ease our builds.
The initial batch produced two years ago was milled out of solid blocks of ABS UV. People requested it, so I took the opportunity to update the design and include a sensor routing hole directly in the riser.
I’m now going to have them produced ABS UV injection molds in ABS UV. If any interest for any bulk order, let me know.
The set will include both front riser and rear riser. 7mm thick ABS UV. I will be able to produce some colors for the fancy builders out there.
My design/idea is the original one, so with all the due respect and unless people using this design without giving credits… I don’t get the point you are making.
You got me wrong because I didn’t respond correctly to balta @okp . I am crediting you for the design and thanking you for making it public before, hoping that might happen again.
It’s not a dig, quite the opposite. These are great.
Of course. I didn’t know who’d come up with the basic design when I saw it on a picture of someone else’s board. I tweaked it along with the cable conduit extension to suit my needs.
You know I’ve already credited you for the original design concept
Could you maybe change the design to have holders for the wires aswell? Like so each wire has some plastic in between them at the end to make it look nicer? i added that on mine else my wire would just be everywhere
