Can anybody share me a productlink or connect me with someone who’s selling this:
i need a top mounted enclosure for a unity it ahould be mounted over the powered axle of the board this means i want to screw it on with the 4 truck bolts of the board
probably something a mtb would use
I am looking for this metoo, let me know if you if you find something:)
I own one myself, very highly recommend @3DServisas. good hunting.
The case has pre-drilled holes in the base plate for mounting to the board.
??? @3DServisas
Just open the case and find the holes inside. And you will only need to drill the holes that you need.
